Oh mines not that bad...
Just revs up and down a bit on cold start up!
Mine also dose it some times even when the cars completely warmed up..
Touch wood bro haha
aww on a cold start,
my iacv is dead, car idles funny hard !!!!!!
but on cold starts .... its usually ok only wen it heats up
bloody iacv. !!!!
No need really...
The emanage is incabable of affecting the cold start.
That is though it can trim the use of larger injectors & change the ignition timing etc. The basis of the cold start is still controlled by the original ECU & factory hardware.
Should there be any issue with the existing factory hardware, the problem will exist, e-manage or not. Infact the emanage could even agrovate the problem.
From memory there is a problem with Luke's IACV as it idles quite low regardless of what was done. The fix is likley the replacement of a few key components.
In any case, anyone who is considering an e-manage aught to think twice & think better of using a real tuning solution such as Hondata or better.
Ah ok fair enough,
I had a similar to do when we rush the tune to get it ready for a track day. Once it was back on the dyno, problem was fixed... so yeh i thought it could of been a similar problem
Hey luke, think you could send me some of the details of where you got your kit? and the prices you quoted on here how much it was to be delivered or is that just the purchase price? Thanks mate!
http://myworld.ebay.com.au/racingimporter
$2080 Delivered
Can't see any listed with him now though
Thanks mate ill give him a bell
you did get it quite a while ago, may no-longer sell it
