yeah i was looking at the mounts yesterday seems fine to me no leaks that i can see i wanna check under the car soon once i get my stuff back will let you guys know what it is once i find it thanks for the heads up
Wakefield track day!
http://www.ozhonda.com/forum/showthr...44#post2369244
Hey Rai c that was me on sat night
1. NightRyder
2. Denrie
3. Perry
4. Rai-C
5. ekhybrid
6. Nepolian
7. sai_ANN
8. White_ep3_civic
9. icecrm
haha sick kient lol what exhaust you running man? looked nice and big lol
[IMG]http://i.ebayimg.com/15/!BT1E,ng!mk~$(KGrH****j4EjlLm(n4WBKKg5FY-7!~~_1.JPG[/IMG]
Yo guys I got it on my car. I just removed a set of DC5 brembos and replaced with Modulo brakes. I can feel slight changes, the dc5 brembo produce a softer braking, while the modulo brakes produce a sharper braking. Both brake system are consider good, except if I were to go on tracks, I personally would prefer the modulo brakes with a more instant braking, especially when i'm on high speed. :wave:
Brief Reviews:
1. The modulo brake pad is slight larger than the dc5 brembo. The modulo brake pad measures: 118mm L x 72mm H. The DC5 brembo pads measures: 118mm L x 62mm H.
2. Since the pads is larger in height, this means the braking surface is also larger measuring from the edge of the center hat to the edge of the rotor disc.
3. And since there is larger braking surface and larger pads, this also means that modulo 4-piston has at least 10% enhancement in compare to the DC5 brembo.
Now I got a set of used dc5 brembos, anyone interested? :cool:
Fujitsubo rm01a
hey guys im looking into getting a ep3 and got a noob question can the dc5 mugen twinloop fit onto the ep3? or would you need minor changes cause i've seen one at a dealer around lansvale with a twinloop
Mid pipe is identical between DC5 and EP3 but axle back isn't.
actually from header to mid pipe, they're the same.
but i guess anything can be made to fit.......
the tip and the muffler are different in length.......DC5's tip is longer.....
anybody here using mugen intake in their ep3 rather than Gruppe m?
