hmmmm, i like to blip every now and then :p. So when i replace my clutch, the problem will be gone. nice to know its nothing too serious.
I don't see what blipping the throttle has to do with the clutch/TOB. When you blip, you match the revs. How does increasing the engine speed wear out a TO bearing?
Some people like to have the car stationary, hold the clutch down and rev the engine up to show off. :) Doing that will wear out the clutch release bearing. That's much worse than holding the clutch down at the lights. I know someone else also with the same problem caused by the same reason.
I had this issue 3 months after I bought the car. I took the car back to the dealer and they replaced the master cylinder. About 1 year later, it started creaking again, I took it back to the dealer and this time, they lubed it. It was ok for about 2 years, but just after the 3 year warranty ended, it started again!!!!
I bought WD-40 and tried to lube the paddle area and the master cylinder, but when I listened to the noise, it's actually coming from the engine bay area. I popped the hood, and asked my friend to press and let go of the clutch peddle and repeat this step until I find where the noise is coming from. And I found it (it's inside the middle section) and lube that part. It stopped creaking, but only lasted few days and it's happenening again.
I am going to take it back to the dealers, but I feel that there is nothing they can do to permanently stop this noise......
I agree that this is a problem that cannot be resolved. Engineering flaw
jooneth perhaps the slave cylinder on the gearbox is noisy.
bmwbadboy yes true, unless you re-grease it every few months. These master cylinders should have its own re-greasing mechanism of some sort, such as a small baloon filled with grease mounted on the cylinder that slowly releases grease into the spring area.
There are 2 creaks. One is on the master cylinder, which sounds like a spring catching onto something. Then there is the slave cylinder, which is a squeaking sound. Don't use WD40 as a lube. It was not made for that purpose. Get yourself some silicone lube for the master cylinder and lithium grease for the slave cylinder contact point.
Have experienced 2 random stalls lately, related to the creaking clutch?
You would think that Honda could have engineered a solution for defect, with so many people having a problem.
