Originally Posted by
SPQR
This thread is still going!
I occasionally experience the right pull but my car has been tramlining less since fitting Dunlop SportMaxx tyres. It's probably because they are new. I have gone against earlier posted advice and I have increased the tyre pressures to 46psi front and 34psi rear. Apart from the slightly "jigglier" ride (and great turn-in), it has reduced tramlining even more; probably because it has made the tyre cross section rounder. I don't think it will increase centre of tyre wear because tyres on the Euro wear the shoulders first anyway.
The maximum air pressure for the reinforced version of the 225/45R17 SportMaxx's on my car is 50psi. It seems that any rim bigger than 16 inch doesn't work well on the Euro. My original 16 inch tyres (205/55R16 Dunlop 2050M) did not have any problems in this regard. But then again, the Acura TSX has 17 inch rims but with taller (larger diameter and profile) 215/50R17 tyres (sorry, tires in USA speak). Maybe Acura recognised that larger width tires (sic) as huge, ultrawide, gi-normous as 225's cause tramlining problems and went for a taller and "rounder" cross section tire (sic).
I believe that the Type R in Europe has 215/45R17 tyres. Has anyone used this smaller and speedometer flattering tyre size on the Aussie Euro?
