It's a third party-supplied part.
Who and Where is best?
This happens on my EG, only on cold days though ? Go figure.. LOL, and if its a cold day and I drive it around, the squeeky noise goes when my engine warms up....
Go figure.
hey guys, i just got a second hand accord euro with 89k kms and it has this clicking sound at the end of the clutch pedal travel down to the floor. Sound starts half way, 3-4 clicks if i do it quick but only around 2 if i do it slow.
gonna take it to dealer monday coming up... it's an 03' so unless the car had a 5 year warranty (which i doubt) i'm screwed :(
anyone know which honda service centres are good in perth? im taking it to burswood honda.
Is it a crisp clicking sound? That is the switch that deactivates cruise control if you have it on.
Mine clicks when the engine isn't even on...
Just spray some Lithium Grease into the Clutch Master Cylinder (located under the steering wheel above the Clutch Pedal, and it should be fine for a few months. If you want it to last longer (say a year), you need to replace the cylinder, which is expensive unless u have warranty.
I had my cylinder replaced like 8 months ago, now its creaking again :eek:
You'd think honda would solve this common issue by now. But then again, my civic had the same problem so perhaps its just something all Manual cars do..
hey guys,
I'm cancelling the service. Just sprayed heaps of food grade silicone that came with my treadmill into the clutch master cylinder using a small 2mm? pipe connector on the can. Doesn't make any noise at all now except for the small click at the top for the cruise control (which is normal from the sounds of it)!
Cheers for this awesome forum and post. I thought I bought a dud, now at least it's not noisy. Can't beat a $10 can of silicone lol.
