It shows u in the manual. It says "extend your arm under the steering column on the upper centre console side".
Basically its somewhere under the dash above the brake pedal. The button is top-down so you need to jam your hand under there and push down. You should be able to see two wires hanging below going into the connector/assembly of the switch.
