One gasket is the shape of the head, the other, the shape of the block - choose your poison, either will block something.
There was a guy that posted pics on b20 blocks with and with ge headgaskets.
Ge didnt block holes where as oem did i forogt where this person posted jt but i will find it and post up
Either way, alot of people are running GE, OEM, Cometic MLS combo's with absolutely no problems.
thank you!
soooo... which holes are you worried about?
top left and bottom right..
if you're worried so much about holes being blocked then you should buy the GE kit
i'd say from those images, th easiest would be to go with b16 gasket and dremel out the oil return holes. at least u wont have to deal with the rivets beingin the way.
