Originally Posted by
yuentinlon
			hi, is me again , now, i have a change to swap for a turbo D owner with my car... i only need to pay 1500... which mean i will save a lot for the new kit and labours... What car? PM me
but here is some question... his D is using stand injectors , should i buy any after market ?? he is running the greddy at 6 psi , without engineered, will that be a problem ? Yes the cars illegal without engineerring
other than the greddy kit.... he didnt do much ... so what should i buy in order to make it run perfect ~ FMIC - Piping
-water/meth injection ?? what will it do actually ... i have no idea = =...
Yes upgrade to RC 440CC injectors + Fuel Pump if you plan to run higher than 6-7PSI
-also i saw a lot of post here... and i think a boost controller will be necessary in order to hold the boost, right ? what should i buy ? E-Boost 2
-i am aiming 0-100 about 6.5s , will that be possible in stock internal ? coz the guys said he use RSM to claimed his 0-100 is 6.7s who's knows but I'm on 14.5 1/4 Mile right now
is that real ?????????? Never trust anything till you see it yourself..
- what should i check before i swap with his car ? Comp test + leak down test.... should be fine though if its only running at 6PSI
 also... anyone know where should i go to tune the turbo in brisbane and how much will that be ? NOPE
