Bringing It back from the dead. Great help and well written.
Brilliant. Rep for you.
hi guys, i just wondering how much does the input shaft bearing cost. cause i heard it should be more than hundred dollars but i went to honda part specialist department they quote me for 36.43aud. i was suprised and i doubt that staff provide me the right parts. thanks guys
I thought it was around the $50 mark. Over $100 surely not
$37 sound correct for an ISB
I'm kind of confused on how to do step 4? popping the lower ball joint?
How does it work?
your using the weight of the spring and the rest of the loaded suspention to crack the lower joint. the braker bar that is wedged between the hub and LCA is needed to force the crack
http://img854.imageshack.us/img854/1461/10052011308.jpg
Which bearing the ISB ??
and where can i get bearing ?what is the bearing number For B000
Thanks
the ISB is located underneath the CENTRAL gearshaft shown in that image.
