ay mate what does that mean?
but some ECU offers limited wheel spin correspondent to rear wheel speed while you use LC function...But a good setup can help a 60ft and ET alot more consistent...
i only know that track temp will either make the track less or more grip..
As RICER said,thats some mighty sophisticated electronics your talking about there,of which ive never seen or even heard of in LCs at the everyday end of the market.
Mind pointing me in the direction of where u found such a product?
Read back a few posts ,u'll see how hard it is to setup,even if being of any use at all on street tyres,before u can get to any level of consistency at all.
I'm just not sure is all the LC function'ed the same way, thats why i'd ask...and that's why i'd said "SOME"...not all...i didn't ask how to tune and all that...
all i'm asking if there is a diff in every ECU that offers LC, what is so diff bout it...thats all...
Yes, there are some High end ECU offers some serious function so that it'll limit the " wheel spin " correspondent to the "Real Speed" when you Launch...just see how those cars offers LC for rear wheel drive...
Remember that a "2 step" rev limiter and traction control are NOT the same thing. I think you are confusing the 2 and adding them together to get launch control. Unless I am mistaken (which does happen ;)) you are wanting both that only comes with very high end systems as has been said. Unless your willing to empty your pockets a number of times over you will either get a "2 step" system (most probably) or a traction control system which is much more expensive and requires many wheel sensors.
Hmm...but does those Ferrari's had TCS while using LC?...
and how F1 launch their car W/o TCS?...
go and ask ferrari.
The 599, does use traction control and has much more advance LC system. Most common LC systems on the market is a pretty much set at a certain rpm where as the ferarri you can launch at any hi rpm and tcs takes over.
F1 cars these days are all manual. No launch or tration control is allowed, except they use their fingers to control the clutch
ok..thanx for all the info...
So i guess Some LC uses TCS as one...
