I compare the V-Power and the BP Ultimate. The BP is powerful than the V-Power. That's my conclusion.
I was really more concerned with whether or not the 91RON would affect my engine?
the best way is read the manufacturer recomended fuel
if it says unleaded, should be no problem
only most performance car, it says premium unleaded
also, there wont be a problem if you use premium. it keeps clean your fuel injector,
about the power, there wont be much different unless if you reset your advance timing, change better spark plug (iridium) like most performance car it use, so better ignite the fuel and match up the timing
i second the bp being better then v-power
Thanks bodaas!
Was only concerned because it had recommended RON levels I think, and I couldn't for the life of me, locate the bloody engine number.
The manual didn't suggest it needs Premium so hopefully it should be ok.
Besides, I don't think the sport is a performance car :p
