Originally Posted by sivic
in regards to the locking rings on the springs (A and B in the instructions i think). after about 1000km jack your car up again and check for any movement of the springs. if they do move a little when you shake them (give them a firm shake) then by all means tighten the locking rings some more on the springs so there is a bit of compression on the springs. this will reduce the noise that some ppl experience and will improve ride quality.
but by all means dont adjust height via the spring.
aDe: quick tip. so you dont have to undo the lower control arm to adjust the hieght- loosen off ring C so its not locked against the lower shaft. then make sure ring A and B under the spring are locked together tightly.
then to adjust height upwards use the spanner and rotate from ring B. as it is locked against ring A it wont move on the thread but rather the entire shock will rotate, unthreading from the lower shaft and therefore raising the height. to lower, do the same but rotate from ring A. rule of thunb is to make sure you are always rotating the ring against the other.
then when you done adjusting height lock off ring c against the lower shaft.
this will save you undoing the lower mount everytime
