finally found some positive info about this turbo
from http://www.pumaspeed.co.uk/showdetails.php?id=217
Power 300-380 bhp
Fitting Charge: £ 287.5Open the door to big Power 300-370 bhp
DIY fit
Fully reliable and tested
actuator set to 20 PSI
All Pumaspeed Turbos Now come with a FREE FORGE actuator upgrade worth over 100 pounds
Wow
Power and torque are on the up 310-350bhp !!! fully reliable and tested. This now industry standard GT2876RS Turbo was the first to be used on the Focus RS and still holds the official record time at bruntingthrpe proving ground
A perfectly balance turbo that will fullfill the power hungry.
Tests on our own development car have seen power of 325-380 bhp dependant on engine spec
GT28 down pipe will be required and a turbo fitting kit
See demo car in the gallery section
The 54mm turbine wheel and 0.64 A/R turbine housing enable ultimate responce combined with powerful air flow from the 44 lb/min compressor wheel.
Focus RS Turbo sizing guide.
There are very complex naming standards in the world of turbo building, so we have simplyfied the naming process to assist in the understanding of the complex world of turbo design and performance,
The GT25 is a std turbo as fitted to the FOCUS RS.
The GT26 is a better version of the std turbo - not popular as a power upgrade - alows for higher boost and minimal flow added.
The GT26Plus Hybrid (we call it a gt26Plus as it still uses the original restrictive FORD exhaust housing although we heavily modify it) - it is for those who do not want to swap down pipes oil feed lines but do want as much as possible from the etc
- can flow 330+bhp and 28 PSI (not that you willl ever run 2 bar !)
- positive boost starts as early as 2100 (mapping dependant)
- is fully gt28 cored (roller bearing)
- uses a heavily modified machined & ported exhaust turbine housing, 71mm high flow compressor wheel from the gt2871 we do,
- complete with with a H Duty billet Forge actuator worth in excess of �100
- Produces an healthy Increase in torque and horsepower over the gt25 std FRS turbo
The GT27 low lag aka. the GT2871RS a true GT28 in all sense of the word.
- requires the gt28 downpipe and fitting kit and is best fitted with a high flow manifold.
- Fully roller bearing cored
- has proved over 350 bhp in this application 390 in others !!
- positive boost starts 2450 (mapping dependant)
The GT28 aka. GT2876RS a true gt28 in all sense of the word.
- requires the Milltek sport GT28 downpipe and fitting kit and is best fitted with a high flow manifold.
- positive boost starts 2650 (mapping dependant)
- full boost near 3300
The GT29 aka. GT3071RS large power 420 is well within it capability, should be used with very well moddified cylinder heads.
- has proved over 395bhp in this application 440in others !!
- positive boost starts 2850 (mapping dependant)
- full boost near 3500
The GT30 - too big for road use must be used with external wastegate and is only for cery bespoke engine conversions 500-550 bhp.
