ok ened up getting the .86 rear, we'll see how i go
Zeforce Can you by chance cruch some graphs again for me?
JUst wondering where the efficency is for a GT2876R with a .86 rear is? Thanks all that cruching is beyond me
lol luke your on drugs you should read wat you post at times.
VTi boi - well based on what i've seen the RS,71 & 76 all have the same rear wheel.
My understanding is they should all react very similar on spool. The different front will allow for more boost..... due to bigger wheel....
Again i'll have to test this in real life. I've seen a R(mine) & RS in action, when i finish i will see a 71(luke's) & a 76(mine) in action.
P.S i'vee seen a GT3/4 in my friend's EM1, does 11s, but boost kicks in like 5k rpm and its abit of a dog to drive around the streets
Then we can compare abit more
http://c1.ac-images.myspacecdn.com/i...00312a2b3c.jpg
NOTE: This is just for compressor efficiency... nothing to do with exhaust housing size
sorry i dun understand, can you tell me roughly what rpm that might be?
Is that basically between 4krpm and 8krpm again?
cool looks like the 60/71/76 & 3071 have very similar efficiency
Now all its gonna get interesting depending on our setups
Yeah, at the end of the day it's all about the right combination of parts, manifold, compressor size, exhaust housing size, exhaust, etc all working together. The 2871, 2876 and 3071 have similar efficiency maps and all rated between 450-500hp but the disco potato (GT2860RS) is smaller and would offer more midrange power compared to the others and is still good for over 350hp@flywheel
just to correct disco potato is gt2860rs
But thanks for your calculations, i'm abit dumb when i comes to complex calcs
No problem I have been messing around with these calculations for my own turbo build. Just a reminder these are simply approximations to give you a rough idea for picking an appropriate compressor size. And I would like to point out for those that dont know, with a well designed manifold, correct exhaust housing size and efficient intercooler setup you may be able to make more power from less boost. For example, you might only need 9-10psi to produce 180kw@wheels with a B16a.
PS: Thanks for pointing out my typo :)
