Apparently its runnig standard compression. Unsure about leak down an comp test. Was never given the dyno sheets but was there the 3rd time it was dyno'd. Probably get a retune early next year.
As far as I know an on the receipt it has had the ceramic internals changed to steel. Ported can see a bit of polished going on in there as well but is not that informing at all. Im just going on what ive been told.
Provides good power right thru the rev range spins 3rd 4th in the wet lol. Will have to take it to the next dyno day that Oz honda has in brisbane aswell should be fun..
Thanks all.
sounds like you have a pretty sweet street set up to me man i bet boost comes on nice and early but even with a flowed t25 theres not much point reving to 9k you say stock internals (10.4:1 comp b16a2) have you done any head work? 9k sounds way high for stock b16a head with stock single exhaust springs but :thumbsup::thumbsup: to the tuner.
If you want more power dont go higher on boost much 10psi with stock rods and rod bolts is a good limit think more flow.
Standard Head, thought it would hit the limiter as most cars would but it didnt an went just past 9000rpm. Did it once more to see how the boost held thought the rev range.
I know theres not much point reving that high but Ive done it now so thats that. Im not gonna spend any more money on it maybe just a dyno tune and redo the intercooler piping but that will be about it im happy with it as it is.
Guys at Hi power brisbane tuned it a couple of times Previous owner payed for that! An theyve done a great job. fuel economy $45 380kms (small tank) around town. Havent done any road trips far away yet.
i get alittle more per tank, but pretty good
i get a constant 400kms a tank in the civic with an EMS i got 670kms out of the tank on a trip once i was happy as with that :)
waste of money... put a b20 bottom end with an AFI turbo kit and your internals that you listed... 10-15psi with s300 you make good deals with AFI customer service 250-300atw
Boost > B20 thin sleeve block.
i sold him this b16a with my DA9, it's a JDM EG6 b16a and they are either supertech or crower retainers (can't really remember), the head was shaved, and i've replaced the OEM headbolts about 1.5 years ago when i installed the head, the head was in a EK9 before which pull 121kw@front wheels with C cams. (b16a head, b16b block)
