Can someone who is currently using 98 RON and has pinging, do a test by running a full tank of 95 RON?
Ethanol is a not a good mix with the CU2, so I'm told. In any event it is a false economy any saving is more than eaten away by the drop in economy. As I said before I'm sticking to the 95 octane. Sydney to Albury on 98 Octane 8.9 L/100k. Albury to Sydney, same driving conditions, 95 octane, 8.8 L/100k and no pinging!
My CU2 has pinged consistently on 95 RON and 98 RON. Have tried full tanks of both - can't discern much difference in the pinging, it's there regardless of fuel type.
I know ppl who has tried both 95 and 98 (at diff time) has combustion (aka pinging)problem. I want to know if anyone using 98 from the begining (except the fuel from dealer) has this problem as well?
Well I run 98 ron, and I no longer have the "noise", actually, I have traced my noise to loose exhaust bolts, that I tightened myself and used aviation grade temp resitant locktite on...seems to not have come back. Maybe some others have this problem and NOT the post ignition issue???
I tightened everything, including heat sheilds, there is no "header" bolts as such as the exhaust manifold is cast into the head. I just went to town with the loctite...
