hmmm if u have a error code, there's no error code for injectors... apart from the injector test circuit on the ECU its self. I'm thinking your problems are not injector related.
Regards James
Regards James
Could be injectors are partially blocked to a tired fuel pump not flowing enough.
Let us know how you go.
Oh, have you tried replacing the fuel filter? Sometimes this item never gets changed and can affect fuel pressure/flow the injector sees
