Originally Posted by aaronng
There is still that point in time where you press the clutch and have yet to get into 2nd and release the clutch. This is my problem. Because the acceleration in 1st up to 4000rpm was strong, the moment I press the clutch, the passengers go forwards.
My problem in not with the take up of the clutch pedal. It is with the change in acceleration at 1/2 throttle 4000rpm when I press the pedal DOWN (clutch disengagement) when doing the 1-2 shift.
Like I said previously, if I shift from 1st to 2nd at 2500-3000rpm without hard acceleration, it is smooth as silk.
The only way I have tried that can reduce this problem is accelerate 1/2 throttle up to 3500rpm so I have hard acceleration, then ease off the throttle a tiny bit for the 3500-4000rpm range and then shift so that the change in acceleration when I press the clutch is not as drastic.
