Have you changed your radiator cap?
Edit:
Car somehow miraciously is not overheating
I installed the new radiator yesterday and it overheated. I cracked the shits this morning and done it again, flushed radiator and put the fluid back in.
Only difference I did today was turn on the heater fan. I read this last night in a DIY thread here on ozhonda
So i did that and took the car for a drive. Drove for approximately 40ks on the highway and it didnt overheat! It sat and 1/3 most of the way but towards the end it was at the halfway - slightly above halfway mark.
I took this into consideration considering my coolant is really really shit diluted stylez
So could the reason of all my overheating be because of the air or whatever it is being trapped through the heater or somin? If so im a bloody retard
EDIT:
Ok, so I drove the car now, at 6pm for about 25 mins on highway, it was pretty tame, heat stayed at 1/3 for 10 mins or so, then creeped up to half and stayed there for a bit. Then it creeped up to 3/4 then started to go back down to half<
What I have seen is that it now takes longer for it to overheat than before, but the problem is still not fixed. It is know able to driven on a highway but still an issue
Options?
like i asked a while back. List what you have done. All i have heard is;
Changed radiator
Changed coolant
Checked thermostat
Is that all now?
When u bled the coolant did you run the car till it got hot with the cap off and the heater on?
If not chances are you've still got air bubbles.
If u did do it properly look back at my last post
Squeeze the hoses lightly, helps get the air bubbles out, just make sure you dont squeeze too hard that the coolant spill out.
There is also a proper bleed valve, you should find it and open it up till coolant comes out.
This sounds like the thermostat. Did those temp changes happen while moving at the same speed or with stopping?Quote:
good. The only time mine moved over 1/3 was from a dead thermostat, which died cos of air bubbles :)
It shouldn't really move now with the thicker core radiator. Mine went to half way at wakefield on a 30degree+ day and only after 6-7 laps going hard
Hmmm, this car hates me
Didn't overheat or move for a fact for 70kms, on my way back from work this afternoon, it decided to start overheat on the highway.
I have ran out of ideas to what can be causing this issue.
I have replaced radiator, coolant, bleed all the air out and checked everything.
What could still be causing it to overheat on the highway. I am getting an air diversion plate made up next week for it, to see if that helps at all.
Ideas?
Haven't had much to do with this kind of thing but i know the factory gauges and sensors can be pretty average, do you know anyone with an aftermarket sensor and gauge to see what sort of temp your running.
If you think it as a whole, the water pump always is running, the radiator is new and so is the coolant, and the only thing that normally stops your temp continue to rise is your thermostat, providing your thermofan is working.
So u would say that maybe your thermostat is sticking, like it pops but when it closes it sticks.
or as limbo said about the bubbles, but you did try that and it stopped for abit then started so maybe you have cracked hoses?
as I said not really touched on this before but just abit of food for thought
a simple test to see if your thermostat is not opening.
take ur thermostat out and dont run one. go for a drive and see if it overheats. if it does, then its not ur thermostat. if it doesnt, its your thermostat.
water pumps usually leak when they are stuffed.
hows your head gasket?
Have you considered the switch/gauge being faulty. My old neighbours charade was overheating, he tried everything and finally replaced the switch and that was causing all the issues (the car was never really overheating). His car also overheated when driving on the highway though
Also what are people talking about not diluting your coolant and diluting it...
You get 2 types of coolant, ready mix (which you don't dilute) such as OEM and others and then you get concentrate (which you have to dilute)
By switch are you referring to the one which controls the thermo fan, if so this is working, as I just tested now, it opens up and turns off like any other car.
Update.
Have purchased thermostat, will be installing it tomorrow, I am also considering replacing the top and bottom radiator hoses.
Also I need a new thermo fan as mine just f****n broke which I just replaced it 2 weeks ago for $65!!
So now hopefully I will see if the water pump is working by when I change my thermostat. If water pump is fine and new thermo goes in and it still overheats I will be taking it to my mechanic/tuner to get that test which detects the presence of exhaust gases in the coolant to determine if I have blown my headgasket.
Should a frustrating couple of days, YAY! :@
