Okay this thread is kind of like a list of things to do to my car to keep me motivated and have a single point of reference as I'm going. I've meant to start it for a while but haven't got around to it. I'll also upload pics of what I need to change/fix and edit them in when I get to it. If you have any helpful comments about something then feel free to quote it and let me know, I appreciate it. :)
Things that need fixing:
- Drivers inside door handle comes out sometimes, need to hold in place to open door.
- Front passenger door does not activate internal lights when open.
- Also the front passenger door does not close properly, like it needs to "close" another 2mm or so, I'm hoping this is an easy fix of adjusting the hinge bolts or something.
- Boot gas struts feel like dead weights, I think they can be re-gassed?
- Drivers chair right-side support needs to be re-padded, someone must have sat on it a lot or taken a lot of hard left corners, or likely just worn from hopping in and out all the time.
- Right rear passenger seat has single small hole, must be from cigarette burn. Can something like this easily be patched up?
- Scratch marks on front windscreen following wipers line, not sure if repairable or needs replacing but it does annoy me.
- Needs a better steering wheel, the current one has scratches all around it and doesn't feel strong at all. Not sure if there's a better one out there that also can take the airbag, or possibly get the whole thing stitched in leather?
Mechanical:
- Calibrate TPS voltage. (need to convince Beeza to do it for me???)
- Research into performance air filters and also mild sports exhaust, was quoted $250 for mild sports exhaust from cat back from a custom exhaust shop down the road from where I work, what do you think guys?
Aesthetics:
- Car needs lowering, was looking up K-MAC lowered springs the other day. Strangely, I really like the standard rims and will be keeping them. Okay I'm really starting to think about saving up for coilovers and just slamming it on the standard mags...
- Plenty of small carpark dings down both sides.
- Windows need tinting.
- Boot spoiler, I actually think it would look better without it, either remove and fill up/smooth/paint or find another white boot and swap?
- Small ding in silver window surround on rear passenger window.
- Black rubber surrounding window frame is coming out and pokes out, always attacks my foam sponge and chamois every time I wash the car (I'm learning to go around it).
- Internal instruments cluster (right-half of tacho) and both air con dials, lights don't come on when parkers or headlights are on so can't see at night properly.
- Also the handbrake release button has some silver chrome-looking stuff over it, most has come off and looks pretty average, would like to have it re-done if possible.
- Want some decent floor mats, in fact if I could swap the whole interior over from my EXi cause it's in much better condition overall. How easy would that be? Carpets and all, but I would want to keep the VTI chair frame because it has up and down electric function.
- Fully clean up engine bay, it's a bit dirty and needs a detail.
Things I have done so far:
- New radiator from Red Devil Radiators Oxenford (always support these guys, they look after me well).
- Have installed Sony Xplod CD player.
- Always filled up with BP Ultimate.
- Tyres rotate, balance, alignment, and filled with nitrogen.
- Plenty of sudsy washes and chamois, including rims and blacken tyres.
- Installed Winnie The Pooh chair into backseat so my 2yr old son can come with me sometimes (best mod EVER).
- Full Stop Brakes @ Burleigh, full brake service. 4 new Bendix pads, all 4 disc rotors machined, new brake fluid. After bedding them in, this thing stops pretty damn hard! :thumbsup:
- Inspected condition of timing belt, looks fine, will look at replacing it at 250,000 kays.
- Serviced yesterday 21/02/2010, replaced engine oil and filter, also gearbox oil - engages gears so nice and easy now, next to no resistance at all!
- Pulled windscreen wipers off, quick sand and paint in black. I'm not too good at this stuff so it's not a great job, but it still looks a lot better - just don't look at it too close! I'll have to re-do it sometime once I get some more paint practice in.
- I don't know what it was, but there was black stuff like bits of tar all over the bonnet and front windscreen. I noticed it after work and it definitely wasn't there when I went out at about lunch time, I may have picked it up on the road or something happened when it was parked. Either way I gave it a quick wash after work and all the black stuff was thoroughly stained into the paint! It was really bad, I was so frustrated! :thumbdwn: So I called up the Touch Up Guys, he came out and had a look, didn't have any clue what it was but he was working pretty hard for a few hours to get it all out. He also touched up all the nicks and scratches around the car, there's a couple that are still pretty bad but it's a lot better than what it was. I sure don't want to go the whole respray route. He also buffed it up so it looks quite nice now. :thumbsup:
Cheers, any tips or comments are welcome but not expecting this thread to go overboard. Also if anyone has info about engines or where I can look, I have a 2.2L VTEC and I found online it puts out 107kW, apparently a H22A puts out 149kW and is a drop in swap? Anyone know about this cause it sounds interesting and I have done some research but obviously not enough yet.
Troy
