Has anyone ever wrapped a entire exhaust system before?
That would be sweet.Just stop at the muffler.Wicked.
There are mixed results on header wrapping. As long as the grade of steel used in the header construction is high ie; stainless, you shouldnt run into corrosive/rust conditions. If you have mild steel manifold, id recomend a ceramic coating first, then glass wrap. Double the heat retention, and you also get the rust resistance of stainless.
