So much win in this thread!
http://www.xposed.com.au/images/Hond...D1-GruppeM.jpg
http://www.xposed.com.au/images/prod...fr-0347kit.jpg
Honda Fit-Jazz GD1 GD2 GD3 GD4
Manufacturer: GruppeM
RRP Price: $706
Special Price: $565
Shipping: Please Login.
[ FR-0347 ]
Description
GruppeM has developed the special carbon duct case for FIT GD1,2,3,4. RAM AIR SYSTEM used maximum space of GD1,2,3,4 engine room. RAM AIR SYSTEM can stop heat temperature inside engine room and can leads cool fresh air from front section.
RAM AIR SYSTEM can make more torque and maximum power from middle range rpm to high range rpm than stock intake and you can feel better accelerate and aggressive intake sound.
The kit is all bolt on kit, so you do not need any modify on your car. All stuff included into the kit.
The limited model which pursued total performance.
It is exclusive design classified by type of each car with carbon intake duct.
K&N four layers wet cotton filter adoption.
The maintenance can make long life works.
For more information, please visit this products webpage.
We guarantee to have the best prices world wide for the Honda Fit-Jazz GD1 GD2 GD3 GD4. If you find a cheaper price please Contact Us and we will match or beat the price.
All Prices are updated regularly according to exchange rates.
This product was added to our catalog on Tuesday 18 November, 2008.
Latest Reviews for Honda Fit-Jazz GD1 GD2 GD3 GD4
Michael Kummerfeld - Date Added: Monday 23 August, 2010
The unit itself (filter, box, pipe etc) are all top quality. The real issues with the kit are: a) you require the standard airbox to modify part of the rubber hose to fit this kit b) the bracket that holds the box to the car does not line up correctly and takes a lot of fiddling to get right. The bolt actually came undone when I was driving and I lost it. I've since had to put in a longer bolt with double nuts and some Loctite to get it to stay there. c) the box cannot be removed without taking the whole unit off the car, not a simple task to replace the air filter d) The clamp that holds the box and filter to the backing plate WILL rub against your battery and possibly through the side of it after a period of time. Responsiveness and torque seem a little better low to mid than the injen CAI I was using. Kit lacks a little polish in the fitting department but other than that it is top notch. 7/10
Rating: [of 5 Stars]
View all or Write a review for the Honda Fit-Jazz GD1 GD2 GD3 GD4 by*GruppeM .
From xposed
