yea... the noise is from the under part(cover) at the bottom of the car.Quote:
Originally Posted by ABS121
you can see and touch the cover at the bottom of the car.
it is cos of that touching the metal at the bottom.
Yeah at Ricks....
Yesterday the creaking stopped for a few hours, i have a slight suspision its the left side skirt. even though my ears tell me its inside, the noise seems to go away in wet weather....
Quote:
Originally Posted by learner
Hows it going Learner
So did Rick's find that?? And what was the fix?
I have a funny rattly noise that gives me the shits coming form the drivers door area ..it is not the windows, it is lower down. Happens every time I drive it above 60km took to it the dealer who said they could not hear it..Waiting to see if it gets worse.
Mine's a vibration coming from the door panel. I can only hear it at high speeds above 60km/h on reasonably smooth roads. I think the door panel plastic weld might have broken. When I put my hand on the door pannel, the buzzing sound goes away.Quote:
Originally Posted by Peekay34
this is wat the job details said...Quote:
Found stone splash tray rattling (touching) against crossmember...
applied padding between engine splash tray and crossmember.
i saw tat padding when i took off the bumper last time...
they really did their job..
BUT the noise still there... so... i will try to apply some padding on the side later... since they only applied the padding in the middle part only.
i have little vibration from the door panel as well...Quote:
i had the vibration from the door panel. it started after i got it back from the first service, which was a while ago now. Took it in for another service last week, and they seemed to fix the vibration from the door panel somehow. However!- there is a new buzzing coming from the B-pillar, behind the bit that covers the unused belt of the seatbelt. anybody else got something like this?
everytime i get the car serviced, it comes back with a new rattle ><!
I have that too. It is the seat belt height adjuster. However, it is very common with Hondas. Did you set it to the highest position? I've heard if you set it one step down, the rattle is not as bad.Quote:
Originally Posted by evolution42
Yeh i do set it on the highest position. I'll try lowering it one step tommorow- thx aaronng:thumbsup:Quote:
Originally Posted by aaronng
Just sent my car to the dealer. They confirmed my rear creak and also the door panel buzzing sound. Will get it back at 5pm today. Fingers crossed!
Excellent, keep us posted.... i took mine in the other day but surprise surprise the creak disappeared on arrival. and then reappeared a few days later.Quote:
I'm back! So far on the drive back and up my car park, there was no more creak!!! Here's what the report said.
"Check for creak from N/S/R when going round on incline & going slowly more niceable on right hand turns.
Road tested vehicle with owner and confirmed creak noise.
Further investigation found noise to be coming from rear parcel shelf area.
Spread apart seams N/S/R parcal (spelling, haha) shelf areas and lubricated as required.
Road tested vehicle again, creak noise no longer evident"
Spread apart seams.. Ouch... But that fixed it. I guess this is the equivalent of massaging the metal that the US TSX forum reported.
I also complained about the door panels buzzing. The report said "R&R both O/S/F and N/S/F door trims and insulated affected areas". The buzzing is gone on flat road (which is good), but a bit of buzzing still happens when going over rough surface (I guess this is inevitable).
