Dude,
since you have done all the IACV,TPS, TB testing/cleaning and still has the same erratic idle....then i would suggest for you to check the below;
-Inspect/adjust ignition timing
-Check/inspect/replace spark plugs
-Check/inspect/replace spark plug leads
-Check/clean/replace dizzy
what fuel RON do u currently have in your tank? sometimes dirty fuel can affect the idle due to the bad combustion in the fuel delivery to the engine.
worth a shot, i had similar prob ages ago, but cant remember exactly how i resolved it.
let us knw how u go....
That's the same as Timmy's (ekcoupe),only the 1st 10 mintues of start up..it's only minor now.
Stupid Honda's! :)
I've found replacing the spring on the tb helps as it gets old,loses its tension and lets in air.
Yeh my problem is only minor too so I haven't paid that much attention to it..
Thanks for the tips IV73CI, I run 98RON BP Ultimate. I'll try the things you mentioned and I also read up that bleeding your coolant might help so might give that a go too.
And if anyone has a spare working IACV, please let me know!
