What was NPcan's stock dyno? I only see a value of 122kW on a Dyno Dynamics but that was with topspeed headers, Injen CAI and Haltech interceptor. He then dyno'd 143kW with WeaponR and Fujitsubo exhaust on a Dynapack hub dyno, which gives higher readings compared to a Dyno Dynamics dyno. So you can't compare the 143kW value to a stock 110kW achieved by another car on another dyno since the dyno & car are different and also because of the tiny fact that the Dynapack has lower loss through the wheels (since there is no wheel attached!).
Features work against you when racing in a straight line or on track as these add weight. CL9 is also 1395kg for the base model and 1465kg for the luxury too. It is a fat car.
Great for acceleration in mid range, but not at the top end which is where you are usually at when doing a 1/4 mile or on track. If on the street where it is more about midrange, driving to beat a DC5R will get your car impounded anyway.
This one is a placebo effect, since the same perceived performance can be achieved by adjusting your foot.
