Ok getting a lil confused...
Yep, correct.
Incorrect.
Incorrect. The CU2 Accord Euro is not fitted with a K24A3 as far as I know, it is K24Zsomething. In any case if you want a K24A3 locally you must get it from a CL9 Accord Euro.
Isn't the cu engine better than cl?
I'm not k series expert. Please inform me
Depends how much you want to spend aswell
The cost of doing k20/k24 isnt worth it compared to gains imo. Yes has extra power from 6000rpm (3-5kw) but the all the money spent on a k series tensioner etc could better spent.
The K20 and 24 head are similar they just have different ports and flanges really. The K20a2 has a really good intake cam, specifcally the secondary intake lobe. The exhaust and intake primary lobes and the secondary exhaust lobe are better on a k24a3. The major weak point in a k24 is the stock VTC
Let me share some useful information. To get more power, you'll need more displacement. A 2.4l bottom is a bang for buck. Here is a good comaprison between a K20/K24 - K20
http://i4.photobucket.com/albums/y13...k24Fvsk20z.jpg
Changing cams in a K20 is pointless. The cost vs gains is useless
Here is the potential of OEM Honda parts in an K24 motor
http://i4.photobucket.com/albums/y13...9/bypfrank.jpg
^OMGWTF are those all OEM parts Benson? Please share.
answer will be
"combination of OEM parts"
http://www.ozhonda.com/forum/showthr...=1#post3160869
^ incredible power figures
What dyno do you use at BYP Benson? Is it a roller or hub dyno?
