And new rotor button
are you getting spark?
did you check to see if you were before replacing everything?
no spark...
do you have spark at the coil like in the video?
does the engine lamp go out after 5 sec when you first turn on the ignition ?
Goes out after about 3 secs! Integra still sitting out the front of my place poor thing. Really want to sort it out over this weekend! Any help would be massive appreciated. Changed to date: rotor button, dizzy cap and ignition module.
so did you ever
- check the main PGMFI relay
- check for PGMFI codes
- check the coil and ICM
if so what where the results
If you're still unsure what to do it may be a good idea to get someone with experience to have a look at it for you and diagnose the problem before piling any more cash into it.
Just checked the pgmfi, contacts close when they should...don't really have a few hundred spare atm to get someone tocome out here and not be able to fix it.
