Originally Posted by
Winno
BEFORE WE GO ANY FURTHER, TURN OFF ALL EQ AND BASS/TREBLE SETTINGS, TURN OFF ALL HIGH PASS AND LOW PASS FILTERS - SET EVERYTHING BACK TO FACTORY DEFAULTS OR ZERO POINTS.
There's three areas you need to focus on to begin with. I've gone into quite a bit of detail but these are simply;
1. Ensure your mids are mounted properly
2. Work on your tweeter angling
3. Adjusting eq settings in the head unit.
So let's begin.
If you can, make sure that your mids are fitted snugly with no gaps between or around them, their door spacers (if you're using any at all) and the door. Any 'leaks' will allow the sound from behind the speaker to come through and cancel the sound from the front of the speaker. This can result in a thinner sound because the bass is being cancelled out slightly.
Fixing this issue enhances the bass and let's the speaker perform properly and give you to sound you're supposed to hear. It also helps balance the sound of the whole system relative to the sound of the tweeters.
Some people even go as far as sealing up the entire door with sound deadening sheets to get truely striking results from 6.5" drivers. I'm not saying you should be going this this extreme but consider if you can, maybe sealing up some of the smaller service holes in the doors as well as securing your drivers properly.
Now that we have that done, let's look at your tweeters.
Many systems with tweeters mounted away from the mids and up high 'can' sound a little harsh. Some people choose to put their tweeters down low in the kick panels or much lower in the doors to combat this. It works but tends to result in a sound that comes from down near your knees rather than straight ahead at or very near head height.
Let's stay with a high mount postion for now and take a look at what we can do with their angles.
Trust me on this one, if the tweeters are in surface and angle mount pods, try swiveling them to face more towards each other. I'd even try swiveling them so far that they start to fire forward and actually into the windscreen.
Try it and see what happens to the sound. Most drivers start to sound 'quieter' when you are sitting out of their direct path or their 'axis point'.
Many high end speaker systems (I'm talking about speakers costing as much as or more than $100k) use this principle to stunning effect. It may also give your sound stage more depth of field so that it's not all so 'in your face'.
When you get things sounding better and you feel that it's as good as it'll get, THEN, and only then should we be moving on to some of the things your head unit can do.
Set your amp to play normal. Switch off all high pass and low pass filters because they don't do what you've been told previously. They're for other stuff.
If you head unit has them, turn them off there too.
Go to your head unit equalizer and if you can, select a frequency around 8 or 10khz to adjust. Depending on how effect your swiveling was with the tweeters will determine how much you may want to turn down the volume on the selected frequency.
If you don't have frequency options up this high, try choosing the next highest one down. Hopefully it'll be something above 5khz. If not, you may just be better off using your standard treble adjustment instead.
If you do have a few frequency bands up high to play with, try knocking back the volume a little on two or three of them and see how you go.
This should help things quite a bit overall. And don't forget that things will settle down from new as your speakers are played more over the next few weeks.
Take your time, and have fun.
