Type R cams,valve springs, retainers, adj cam gear, thinner head gasket, shave cilinder head, fuel press reg, fuel pump, Ecu and final Drive...
hmm..might be able to keep up...hmm...
or do what TODA AU said...much better!..
can civic b16a internals run toda c's at 9k?
with the right internals a b16a civic hatch will have no probs with type r's or s2k's, Loonee's yellow EK is a perfect example of that
The thing is CAN C CAM RUN WITH STAND PISTONS ? toda pistons required i saw the web site.Quote:
Originally Posted by BlitZ
such as.....lawz?... :oQuote:
Originally Posted by panda[CRX]
Dont muck around, simply put a type R motor in cause you're not going to get much more power by bolting on mods.......if you cant beat them join them! Hehehe
Boost is your next option
i dont know off the top of my head but i'd say itwas pretty similar to the list adrian put up. i'll ask my mechanic that built the engine, otherwise u can ask loonee himself;)Quote:
Originally Posted by J-MuN
Im not even gona bother wasting my input on this one
:goes to the bar fridge and grabs a beer:
You can but you will never get the power out of the camQuote:
Originally Posted by ATSEK4
My fd have very good results with Toda B + CTR piston, of course with some other mods
IF i get type r throttle body and manifold
type r cams, value springs, retainers, port and polish head
up compression to r spec
would my output be same as r?
no. believe it or not, displacement actually counts for something:rolleyes: also, the b16 intake manifold is better suited to the b16 then the type r item
A stock R maybe! But an ITR with same mods as you and the right tuning will allways be ahead of you in power :SQuote:
You need to take advantage of your chasiss by dropping as much weight as possible.
You should then look into your tranny and add a light weight flywheel/4.785 final drive and LSD.
Power wise you already have a head that flows comparably well compared to the R's. Your main weakness is your lack of displacement.
I would recomend you source a second hand R block,mate that to your head and drop some CTR/ITR cams with ITR valve train, Tune with Hondata and you'll beat R's daily and twice on Sunday.
Sorry about the rant.
-Joe
