Hi all,
I tried numerous time and it didn't work. Just before you do step 1, do you have to turn it to ON first and then turn it off, follow by step 2.
1. Turn the ignition switch off.
Thanks.
Aaron
Hi all,
Thanks.
Aaron
/// From the workshop manual:
Audio Unit Self-diagnostic Function
How to apply the self-diagnostic functions (without Navigation)
1. Turn the ignition switch to ACC (I) or ON (II).
2. While holding down the up of both ‘‘REW'' and ‘‘DISK+'' buttons simultaneously, press the power switch.
3. The following BUS communication DTC will appear on the sudio unit dispaly.
4. By turning on a switch while the DTC is displayed, the input will trigger the DTC mode that is assigned to that switch.
PLAY/PROG switch
Entire LCD lighting mode: Lighting the entire LCD to show the presence or absence of an LCD failiure.
NR switch
Entire LCD lights-out mode: Turning off the entire LCD to show the presence or absence of an LCD failure.
DISK+switch
Display I2C-BUS communication verification status: TO display the validity verification of the communication among the DISP, EEPROM and TUNER.
5. DTC mode will cancel when the audio main power switch is turned OFF or the ignition switch is turned OFF.
Display Specifications (without Navigation)
No. Verification items Verification results
1 Entire LCD lighting ———
2 Entire LCD lights-outs ———
3 I2C-BUS communication verification status DSP communication OK
4 DSP communication NG
5 EEPROM communication OK
6 EEPROM communication NG
7 TUNER communication OK
8 TUNER communication
hey man, nice discoveries of the hidden diagnostics
I just copied your instructions and went down to the garage on this cold and wet day to try it out
but a bit dissapointing, thought the displays would be much more graphical than digits and can't stop the menu number flashing...
and... is it my euro or a common, that don't try this hidden diagnostics with a cold engine...
see... by pressing AUTO and DUAL, my air con went cold as... maybe previous setting... and with a engine trying to warm up... no good...
for the next few minutes, some strange engine shake was happening...
hope it dosn't become permanent...
anyway thanks for the tip, pretty cool to see actual temperature figures and talk about aussies radiation figures...
Got a question... my CL9 air con is blowing out warm on the driver air, even in the 'LO' setting. pax side is alright, though. activating the built-in diagnostic, and looking at sensor 6 (driver side air mix), it throws out code D2, D1 and sometimes, some Cx and Ax..
does anyone have any idea what those codes mean?
thanks.
Turn off "Dual" mode and check what does option 7 tell you. 6 should show the same as 7 when "Dual" is off.
turned off dual, 7 reports 01 at 'LO' temperature setting, 6 reports 'D2'
it looks like electrical or data comms problems, the relevant fuses are all fine.
Looks like the vent which controls the cold air mix for the driver's side is stuck! Warranty time.
20 days? They don't even have a spare jazz to lend you? :(
I love it when people find these things out. There a post a while back that was also very similar and I found out that if u hold down the unlock button on your key and hold it it actually opens all the windows.
I'll defintiely be trying this when i get in the car.
:D
