Nope. All internal
Nope. All internal
And in calculating the strength of the design, the Engineer would make certain assumptions regarding weld strength, HAZ etc. From what I can see of the welds, I would struggle to assign any sort of reasonable strength, fatigue or geometric load factors to those welds.
Not trying to criticise or be a dick, but welding critical structures should be left to the experts, and what I can see of the tack welds, that's not expert workmanship.
Thanks for your feedback.
I am not worried about the tack welds as that is all they are. Tacks. It will be welded up correctly once it is all lined up and fits
Quite a interesting build you have going there, I raced Super Mini's back in the late 70's and early 80's and now have a Honda, weird ha. There are a few honda powered Minis still racing around these days if you are in NSW maybe try to get to a meeting and check out their set up's.
Or check out Facebook NSW Suoer Mini Racing page maybe contacts who can give advice.
Back in the day we used to raise the front upper control arm to help the drive shaft run straight to prevent excessive wear on the CV joints.
Good luck with the build.
Thanks Howardm. I just liked the page to follow. Looks good.
A week off work to get stuck into it. Main frame done and engine mounted. Lower legs and rear cross brace with engine mount still to go in.
http://images.tapatalk-cdn.com/15/10...894e77a6a8.jpg
http://images.tapatalk-cdn.com/15/10...6fba78748b.jpg
http://images.tapatalk-cdn.com/15/10...23c63c6e85.jpg
http://images.tapatalk-cdn.com/15/10...c8bc3f71e1.jpg
YellZCHYEEAAAAAA
Frame all welded up, engine wiring harness re-taped. Now working on the rear engine mount, lower control arm mounts and gear linkage.
http://images.tapatalk-cdn.com/15/10...e3b44ee928.jpg
http://images.tapatalk-cdn.com/15/10...ae6b9a410f.jpg
http://images.tapatalk-cdn.com/15/10...2d5696be13.jpg
http://images.tapatalk-cdn.com/15/10...5724f32201.jpg
http://images.tapatalk-cdn.com/15/10...8580146cc0.jpg
fuk yeh
Part of the fun: engine in, engine out, engine in, engine out.
This time to get the castor rod mounts tacked in, rear engine mount tacked together too.
http://images.tapatalk-cdn.com/15/10...5c725c4857.jpg
http://images.tapatalk-cdn.com/15/10...fafee2a4d7.jpg
Back on 4 legs. Suspension geometry seems quite good by eye.
http://images.tapatalk-cdn.com/15/11...a5e4450a12.jpg
http://images.tapatalk-cdn.com/15/11...4a9ef66652.jpg
http://images.tapatalk-cdn.com/15/11...2a14ef1c67.jpg
http://images.tapatalk-cdn.com/15/11...22ee6da729.jpg
