whats the exact specifications of the bulbs u used if its not too much trouble?
really wanna do this simple mod..
If you really want a bright one, buy from www.superbrightleds.com
For parker & door light: WLED-WHP LED Wedge Base Bulbs http://www.superbrightleds.com/mini-wedge.html
For dome light: High Power LED Festoon Bulbs http://www.superbrightleds.com/festoon.html
Which ones are going to give the best warm white light for the dome and door lights?
Just did mine, so much better with leds as you get cool white and not warm white.
Parts used was purchased from Jaycar(.com.au)
http://www.jaycar.com.au/products_up...arge_10819.jpg
Door Lights, ZD0309 $6.95
http://www.jaycar.com.au/products_up...Large_9227.jpg
Interior Lights, ZD0480 $14.95
You can also build one yourself and pick your own LED colour or a brighter one. Purchase this and add your own choice of LED.
After I bought the above I checked DSE and also spotted these and they are cheaper.
Goto www.dse.com.au and search for P8621, P8621 and P8621.
Pix
http://cthr00.com.au/qd/lk.jpg
http://cthr00.com.au/qd/lk_installed.jpg
http://cthr00.com.au/qd/lk_installed_ba.jpg
http://cthr00.com.au/qd/lk_door_b.jpghttp://cthr00.com.au/qd/lk_door_a.jpg
Might return one of the ZD0480 for the rear cabin light and try the DSE one.
whtie makes things harder to see tho.. ?
I kept all mine stock however made the door lights (the ones when u open the door) red LED.
So its very european looking + safer - usually.
Idea stolen from Adammet04 lol
Sorry to dig up an old thread guys, but I relly need help in removing the overhead map lights. I have read the thread and also the manual. It says to "Pry" on the outer edge with a small screw driver. I do that but they still do not budge. Please can I get a step by step from someone who has done this please.
Basically I need to remove the whole overhead console as I am looking to route my wires for my Auto Dim Rear View mirror in there also.
Please help!
you pry one side then pry the other side and it should clip out.
don't forcefully or you snap the casing hooks.
stick flathead vertically up into the slot, then pry towards your direction.
i got the white led's as well for the centre lit in the roof and the doors. i got them locally at a place called Tougetune in Rydalmere. The centre one i have is better than the one shown in the picture as it comes with I believe 8 LED's rather than the 4 and it is bloody bright !!!!
they are absolutely awesome, especially at night when you're walking to your car and you use the keyless entry. It has this awesome glow and because my interior is beige, it brightens up so much more..
My dome lights has 12 LEDS!! its super bright! I also did my courtesy door lights too but you will notice they begin to flicker sometimes with vibration or if someone SLAMS your door very hard...e.g pissed GF HAHA!! Easy way to rectify the flickering is to bend the metal wires diagonally rather than vertically... Don't push the courstesy door lights too hard as the socket within the door will push through!! its happend to me before!
