Hey CRX_16x ...
Not sure about the bushing ... never occured to me to change it actually...
I've seen some aftermarket cross members that sell in the US that supposed to help with traction ... but they're pretty expensive .. I think it's by a company called Z10 or something?
I'll lookup Fulcrum anyway .. thanks.
If you can weld, or know somebody who can, there is not much to them.
Here is a great thread on honda-tech http://www.honda-tech.com/zerothread?id=957387
You can buy rod ends at http://www.m-msport.com.au/Motorspor...E%20Rod%20Ends
EG5 does EGk20a run a full race crossmember?
haha phil. stop lying and show everybody you're snail ;)
you mentioned that you're slicks were a bit too tall and you got a bit of scrubbing - could this have affected your 60"?
with decent suspension work, some bars on the back and 1.5x 60foot, that will be a mid 11sec car.. good work. :thumbsup:
mugsee - never !!!! I will never go over to the dark side .... Lol
Online - hmmm... stop giving me ideas !!! Lol
The missus is already on my case :)
BUT ... when you say suspension work... you mean ... get drag specific suspension? Any tips.. advice?
Running tein HA at the moment. Have not had a chance to get the settings right yet... not really sure what the optimal settings are.. guess will have to play around a little
Also .. is there a difference between running 13 vs 15 minch slicks?
Thanks
phil ur tien HA wont be helping much, thats why ur 60foot times arent so good.
a better suspension alone woudl net u 0.35seconds at the 60ft. You can see the difference just suspension alone makes between the 2 integras.
Hey pornstar ...
What susy setup do your suggest? What setup were you using when you had your car??
Big_red,
I'm really confused. Not doubting you just confused?
Can you give us the full spec of your car. From what I'm reading it sounds like you have a mildly modified B18C (type R) in an EF CRX weighing 1050kgs and it's capable of running low 12sec passes. It just doesn't add for me, even a mid 13sec pass doesn't add up. What's your secret?
good quetion, how much HP does it put at wheels.
i was running low 13s in my 200sx with real s"_+t 60ft times, best mph was 113mph
i had sr20det fmic 3" zorst running max 12psi, putting out 280rwhp car weigh 1240kg
putting out 122kw at the wheels ...
