can you 'clay' the clearances yourself?Quote:
Originally Posted by spardikis
it is fairly easy and will give you peace of mind:
place blutac in the valve reliefs and put a used head gasket on:
http://members.iinet.net.au/~joannep.../10aug.009.jpg
swap the VTEC pistons in the rocker arms over so that one valve is in VTEC all the time (you can do just one cylinder)
http://members.iinet.net.au/~joannep.../10aug.004.jpg
then put the head on, torque it to specs, put the cams in and put the timing belt on:
http://members.iinet.net.au/~joannep.../10aug.013.jpg
crank the crankshaft around a few times (so that the piston beign 'clayed' is at TDC at least 2 or 3 times) and then remove teh head and see what happend:
http://members.iinet.net.au/~joannep.../10aug.014.jpg
then you can measure with a metal rule how much clearance you have:
http://members.iinet.net.au/~joannep.../10aug.015.jpg
if you are using adjustable cam gears, set them to full advance for the intake and full retard for the exhaust, (but if you are quite fearful of piston to valve contact, start at maybe half advance and work your way to full advnance (or vica versa)...)
