It's behind glovebox, on the top left side
Thanks mate.Damn not convenient.
Apart from the ECU Fuse is there another one that I can pull out in the fuse box in the car that will prevent the car from starting?
Careful when u pull out ECU Fuse. You have to start car and let idle for at least 10 minutes minimum or Radiator fan kick in twice to allowing your ecu to "learn". Check this link http://www.ozhonda.com/forum/showthread.php?t=38742
^^ Yeh totally resetting the ECU fuse.That's why it's better to not take it in or out.
Is there another one that I can pull out in the fuse box in the car that will prevent the car from starting?
probe the main relay with a test light till you find the fuel pump power wire, then wire a switch in series to it.
I'm will be installing a fuel pump cut off switch but I was just wondering if there was a fuse I could remove aswell.
no fuse
^^ Thanks mate.
so anyone know the part no. of this relay if i wanna replace it?
John, did this to our 90' Accord EXi
you saved me over $100 to replace the f0cker
thank you
