which is the better way to go for an EG.. 22mm / 23mm?
whichever is cheapest basically.
you wont notice a difference between them.
Im still sure a DC2R swaybar whether 22 or 23mm and its less forgiving design will rip thru a EG subframe in only a matter of time.Quote:
Originally Posted by Paul1985
IMO save the hassle of the EG subframe and just get a whiteline kit with reinforcement + tiebar ~
yeah, you need re-inforcement on an EG,
sorry for implying otherwise ;)
bring up an old topic :] For a DC2 if I was to get any swaybar bigger than stock would that mean I would need to reinforce the subframe? How about the ITR front sway bar? Is that just bolt on?
JDM DC2R '96 spec, AUDM DC2R & DC2 all have 24mm front sway bar. perhaps the only difference may be the stiffness of the rubber bushes used. If a larger than about 18mm rear sway bar is used you should fit a reinforcement kit. Stock is 14mm.Quote:
Originally Posted by zorrt
if you get a type r rear sway. You can buy beaks reinforcement kit, or you can make your own or buy one from brett's gsr site.Quote:
ITR front sway bar is same thickness as DC2 vtir, so no need to change
http://integramod.tripod.com/perform/suspension.html for more information
