yeh i'm having the exact same problem
just gonna take my block to the mechanic so they can take the bolt off with an air compressor gun and do the rest myself basically.
im having the exact same problem. I spent more than 5 hours today trying to ful this SOB bolt off. I tried everything, the method shown, rattle gun, i welded up a ghetto bracket to try to hold the harmonic balancer. The last way is the closest i got, when I tried to crack the bolt with the breaker bar and a big mofo pipe on it, I snapped the 1/2" extension that i had on the socket/breaker. I have never seen a 1/2" drive anything snap before so I am thinking, I'm gonna put it all back together tomorrow, take it to my cousins worksop on monday (truck mechanic) and get him to see if he can loosen the mofo with his 3/4" drive rattlegun then nip it, bring it home and finish the job.Quote:
Originally Posted by VTi-R Civic
But its pretty depressing, whole day for one bolt. My mate was with me was a mechanic and he was cracking stupid jokes like 'i forgot to tell you i failed bolt removal fundamentals at tafe' and so on. but yea. LONG DAY
yeh man, that was the most depressing thing about my swap - getting that thing off..
but i mean, at this point, just stop trying.
I took it to a workshope and took them 10 seconds.
Dont break anymore equipment - like i did. :)
I had the same Prob, even with a rattle gun. I eventually took the Starter motor off. Cause putting in First,with it jacked-up, wasn't doing anything. Jammed the Flywheel teeth. Finally came off, with a bang. I thought...Shit...Was that Teeth on the Fly wheel?...But it was just the Bolt letting Go.
Good luck.
yeh i put it all back together and am going to buy a BIG MOFO rattlegun. My 1/2" one is useless. Only good for wheel studs and other softcore mech. work. I'm gonna get the magnum rattlegun, do a clint eastwood. 'do u feel lucky punk.. well doya'
trying to get the crank bolt off.
i bought a 2hp compressor and hired a gun from kennards which didn't do the job after constant smashing the breaker bar to loosen it and using the gun too.
the engine is running and on its wheels and drivable but it's leaking to much oil to drive it down to the mechanic to get him to remove it.
do lube mobile carry air compressors / impact wrenches?
I would call them but they are closed atm.
and what size compressors?
maybe they can get the bolt off.
if not does anyone have any further advice for me?
my compressor is a 15cmf, your 2 HP compressor is probably arount 6 to 8 CMF, just wont cut the cheese,
try using a bigger bar and hit it harder. the hit it with a bar method works, trust me, you should be able to loosen the bolt enough so your compressor will get it out. you just gotta be persistant.
some are easy, one whack and the gun will do the rest. ( like in this Video )
some are real biuches, have to beat the crap out of it before it will give. ( like in the Cambelt Video )
how heavy and long is the bar your using.
the bar was longer than 1m
me and a mate both spent 30 minutes whacking the crap out of it
used the gun on it today
along with whacking it hard
didn't do crap
i did round 2 yesterday, thought i would try crack the crank pulley bolt befoore i did anything else just in case i got stuck again..Quote:
Originally Posted by michael_antoi
GUESS WHAT??
THE POS BOLT DIDN'T COME OFF AGAIN!!!!!
I tried everything again man, Im just over it 100%. I've never seen a more stubborn bolt in my life. My dad was sitting with my drinking beer and he was giving me moral support by swearing at it in greek for me while passing me tools. As for the 12cfm compressor scenario. I have a 15cfm compressor and my 1/2" drive rattle didnt even budge it. Im going to borrow a 3/4" drive of a frd of a frd next time and see if we can get this biutch off. Im not gonna give up this is about principles now. Think about it..
'what did u do this weekend?'
'working on the car?'
'oh yeh, what did u do?'
'tried to take off a bolt'
'ohh... ok then.. better luck next time.'
there is no way im gonna let 1 bolt get the best of me.. I would rather attack the thing to the point where i snap the head off the c**t and have to drill the fu**er out.
the mission continues............. stay posted
lol tough luck man
just take it to the mechanic.
thats what i did the first time
took them 10 seconds - literally.
what size air compressor u got?
i was gonna hire the 3/4 inch drive but u need a 10hp + compressor
10hp+ really. I was told you only need 150psi to run the 3/4" drive. My compressor pushes that pretty easy so I was hoping i could borrow it. I might just take it to his wkshop and get him to crack it then nip it back till i drive it home like i originally planned.
I cant take the car to a mechanic man, i will feel like i failed, ok if it was something that i havent done before, but a timing belt damn.
you ended up taking it to a mechanic to do the whole job or just take the balancer off??
just the balancer - there was no other way i could have gotten it off
kennards said there is no way my 2hp compressor would be able to power the 3/4" drive
he said i would need something close to 10hp
