yes i understand the rear subframe is different between DC/EG and EK/EM, and also type-Rs and normal civics bennjamin, what i'm trying to get straight is wether the ARBs itself are the same, i have been told that the 22mm bar from the EK9 and pre-98spec DC2-R uses the same D-bush and bracket whereas the post-98spec JDM DC2-R's 23mm bar use a different D-bush but the same D-bracket as the 22mm bars. :confused:Quote:
Originally Posted by bennjamin
