Firstly test the tester is working.
Hook up the black wire off the tester to a good ground(cant see in the photo whether u did this or not but i assume u did).
Then touch the tester on the battery positive terminal to make sure it lights up & is working correctly(Do this with any test equipment to make sure its good,before it leads u down the wrong path).If it lights up & is working correctly,leave the ground clip(black wire on tester) where it was because u at least know it is grounded correct where it is.
Did u test both pins in the plug?
i assume u did this as well.
Is the common wire between all 4 injectors yel/blk like weve been discussing?
If still no light on tester when u done all this,then next step is to look at the main relay & possibly after this look at the ignition switch.If u confidently can hear the fuel pump prime when u first turn on ignition than ignition switch will be ok & its definitely a prob with one of the coils in the main relay.
Find the main relay & u will possibly see 3 yel/blk wires.One will be by itself(this will be the fuel pump wire,ignore this wire).
The other 2 yel/blk wires will be joined to the same pin(one goes to the injectors(branches off to all 4 injects at the shock tower) & the other goes to the ecu)
Turn ignition on & in the same manner as above ,test that your tester lights up when u touch these 2 yel/blk wires at the pin.Dont forget to test tester first by touching it to the little bit of exposed metal on top of the fuses under dash(a few of them should make it light up with ignition on,not all)
If still nothing,test the blk/yel wire on the main relay makes the tester light up.If it does than u need to either read this DIY (by ECU-MAN again)
or borrow or buy a new main relay.
Go thru all the stuff above before buying anything thou & dont forget ALWAYS TEST THE TESTER
