Quote:
Originally Posted by XP02ED
blue bits
just run the vtec bulb from engine bay back into the cabin so u can see it while driving obviously
edit:dont forget to remove D4 from ground before u disconnect battery for the last time.
blue bits
ok sweet i get it
aiight but i still dont get how A13 and D4 will signal the light bulb to flash and stuff?
is that something the ECU does?
BTW once ive set this up,
i can setup a Vtec globe aswell reading post which we talked about to see when vtec engages!
what im gna do to minimise wiring right,
Connect A13 and to A23/A24 to ground it, Positive end of the bulb t D1
Connect D4 to A23/A24 as well to ground it (i might put a switch between).
BTW going by this layout :
http://www.ff-squad.com/tech/wiring/obd1.ecu-pinout.zip
____________________________________
once this is setup ill make a kool setup to blink stuff when vtec engages ;D
Blue bitsQuote:
