I think you all need to brush up on your basic comprehension skills if you think I said that track times are a good comparasin between two cars power outputs. I simply said that the quater mile was the best place to test out a cars usable power (isn't going fast the reason you modify in the first place? A dyno sure isn't that exciting in my opinion).
Barefootbonzai, is there a reason you are getting so hostile? Apart from not being able to understand my simple remarks, you are not adding anything by trying to insult me. Because you are so aggressive, I assume I must be in the wrong here, which means that of course when you took your car off and put his on, you took your front wheels off and he used them right? You also had a wheel alignment on both before, giving you the same alignment settings? You monitored both coolant temps and made sure that before each run they were exactally the same? There are an infinite number of variables I can come up with as to why you could get different results 5 minutes apart on two different cars. It's a completely dumb comparasin unless they are deadset identical.
Finally the truth comes out that both motors are untuned.
Does Lower Final Drive Change Dyno Numbers? - Nowhere near as much as not tuning your car properly.
First I give you an answer which apparently is "totally off the mark", basing part of this on results which are 100% invalid in the first place.
You're turning into the boy who cried wolf, but instead, your the "boy who claims wrong"; you are simply becomming anoying to reply to, as you are more interested in hearing what you want to hear, rather than facts.
This entire thread is completely useless until you get both cars tuned. Then come back with the results and we might be able to have a reasonable discussion on why each car produced what.
fatboyz39: Do you have links to these claims from Limbo, or are you just agreeing with him for fun?
