Originally Posted by BlitZ
well i guess you are making progress..
If you are sure everyhitng is there.. ie, fuel, spark, crank..
There its proabably sometiming issue which i am sure you already know..
Check as what everyone else has said ..
I would do it in this order:
Visual only check Spark plug firing order...
then
timing belt as if this is off you could end up with bent valves..
To do so.. jsut remove rocket cover...
Set to it TDC... ie. 2 up arrows to the top and the indicators (or slit) on the cam gears facing each other..
then get under the car and make sure your crank pulley's red line is align with that triangular prism on the lower timing belt cover..
Then if its all correct..
Go for the Dizzy...
