What is your budget? I can't believe no one has asked yet.
drop it 2"!!!
on 17's just rite
i dun have any probs on humps or anything
[img]C:\Documents and Settings\son\My Documents\My Pictures\120_2020.jpg[/img]
heheh some1 tell me how to post piccies??
im a blonde
You funny bugger... :lol:
You need to upload the image to webspace somewhere and link it that way or use your personal gallery. You can't link from your computer. :)
LOL booget!!
HAHAHAHA
hahah son you damn blonde!!Quote:
Originally Posted by booget
if you want email me the pic and i'll host it for you
mhor@iinet.net.au
Have a look here on how to post pictures Blondie :DQuote:
http://www.ozhonda.com/forums/viewtopic.php?t=699
hahahah thanks fellas
friggen and im studying computiong
farni
i got a couple of quotes to drop my bitch today
kings superlow ($500) + koni adjustables ($1000) fitted
or a set of coilovers fitted for $1500
only prob is one of the suspension joints said i might have "driveline vibration" if i lower it 50mm
anyone have this prob with their DC2?
cheers
I got Jumboz springs on my car wif stock shocks...If u r on a tight budget like me then just get springs, but I must warn u that it is a pretty rough ride!!! Everyday to uni it is like, BUMP OUCH BUMP OUCH. I have put on the springs for around 5K kms or so, and so far shocks seem to have no probs and yes it will sag (Mine have only sagged a little, not much).
I have dropped it like 2.5 inches and i reckon it is perfect height, well a tiny bit lower would've been good ;) , and if u lower it 1.5" u will be kicking urself silly as to why u ddin't lower it a little more!!!
Hi guys,
My vtir is sitting on k-macs 2" drop, the guards sits just above the tyres. so it think if you want to get rid of the gaps you may need to go 2" instead of 1.5"
Also no one has mentioned that by lowering your integras your tyres are going to wear unevenly, most likely negative camber. So you will also need to get a camber kit to correct the angle. Or if you are on a tight budget you can just swap the front wheels with the back wheels once the inside fronts are worn. THen once these are worn you can then swap the back right tyre with the front left tyre and the front right tyre with the back left tyre, drive until these are worn. Then swap the front wheels with the back wheels. So as a result you are getting 4 uses out of them, however you will need to go to the mechanics or tyre shops to get them to switch the tyres for you.
Sweet as. :)
I think Jumboz are kind crap like someone said earlier they tend to sag after a while. Go either for kings,k-macs, pedders are ok or if you have the bucks go for Tein. Now these are sweet.
cheers.
which coilovers???Quote:
Originally Posted by EG_2_TEG
whats driveline vibration?
