Aim:
Install neon’s under the seats/dash board, boot, and front bumper
Required:
Screw drivers, Duct tape, neon’s, lighter, scissor,
http://img413.imageshack.us/img413/6104/cimg0918hn2.jpg
Steps:
cut all the wires and strip them.
http://img145.imageshack.us/img145/8946/cimg0920eo5.jpg
boot:
measure the neon’s length and drill 2holes on the parcel shelf, run the plastic ties thingies though the holes to secure the neon. And then run the neon’s wire to the front under the dash with your sub/amp wires.
http://img109.imageshack.us/img109/3159/cimg0932jr4.jpg
under seats:
first find a spot you want the neon to be under the seats. Put/peal the double sided tape on each end of the neon, and then just stick it on.
http://img114.imageshack.us/img114/4227/cimg0924mg8.jpg
http://img114.imageshack.us/img114/6703/cimg0926hy3.jpg
and then run the wires via your center console to the front, if u cant get it in try use a pen/screw driver to help u
http://img164.imageshack.us/img164/1452/cimg0921jx0.jpg
under dash:
Find a secure spot so you can use the plastic tie thingies to hold the neon’s under the dash.
http://img267.imageshack.us/img267/4695/cimg0929la2.jpg
Front grill:
With this one make sure your neon is water proof be4 you install it, also you might want to give the radiator a clean/wipe as well.
Same as all others find a spot for the neon to settle, tight it down with the plastic ties and you can also use double sided tape to help you secure it. Run the wire up to you bonnet and around the side (make sure it’s away from the engine belt or anything that may get HOT during driving) up to the battery and then put it though the fire wall along with your sub wires.
http://img92.imageshack.us/img92/1003/cimg0936fk7.jpg
http://img267.imageshack.us/img267/927/cimg0950ez0.jpg
Connect:
By now you should have all the wires from 6neons sitting under the dash ready to b connected/. Twist them together +ve with +ve, -ve with –ve and leave it there for a moment.
Run an extra wire from the front to the boot (again along with your sub wires). When the wires get there remove/lift up the plastic pieces to allow the wires to go under/though to be connect to the boot light. Be4 u touch it, turn the switch/light off. The use sodium iron to connect the wires and then pop the light back in., and leave the switch.
http://img232.imageshack.us/img232/293/cimg0930mu4.jpg
http://img178.imageshack.us/img178/7241/cimg0931lk0.jpg
Back to the front, now u should hav the extra wire from the back and all other wires from the neon’s there. Connect them together by using a clip or duct tape.
When you’re done. Double check everything be4 your turn the switch on the boot light on. Once it’s on the neon’s should light up... if not then…. Read the Disclaimer on the top of the page :/
http://img110.imageshack.us/img110/5205/cimg0945ai9.jpg
http://img126.imageshack.us/img126/5669/cimg0948zb0.jpg
http://img126.imageshack.us/img126/8675/cimg0949vd5.jpg
http://img126.imageshack.us/img126/3503/cimg0944xm1.jpg
Other comments:
-If some how the 2wires (+ve & -ve) came in contract, and the light don’t work any more, no need to panic you probably just blown the fuse. Go open your bonnet and change the interior light fuse (7.5) in the fuse box if it’s broken.
-I don’t know about other cars but in mine the boot light comes on as well when the door opens. If yours doesn’t then you have to connect the neon’s to the interior light wires under the dash some where :/
-if you don’t trust the wiring afterwards then go buy a fire extinguisher and keep it in the car
