Hi Whiteline,
I got a Whiteline adj rear bar, along with the rear subframe reo kit, front and rear strut braces fitted about 9 mths ago by the highly regarded Wilkinson Suspension in Perth.
Could you advise me where I stand with regards to my current setup? ie is there a newer/improved version out there currently? Pls find images attached.
Ever since I had the kit fitted there has always been noises ( tock, bang ) whenever I corner hard, esp on hard 90 deg left hand turns ( may be to do with the LH rear wheel off the ground and spring unseated as well? ). I thought the noises would go away as the bushes settle in but they haven't.
I must stress that your products have totally transformed the way my car handled and I haven't experienced any handling problems associated with the noises, so merely an annoyance.
Should I 1st check the tightness of all the bolts 1st? If so what are the recommended torque settings? Pls advise.
Thanks.
http://img464.imageshack.us/img464/8...4586ud6.th.jpg
http://img464.imageshack.us/img464/2...4587vn0.th.jpg
