I don't find it easy. If I showed you only the power chart on the right could you predict what the torque curve on the left would look like?
http://blkcrx.hondata.com.au/blkcrx/...ch/compair.jpg
I found some charts for the Injen for the TSX on their website. Have a look at the torque graph between 2000 and 3000rpm. The base line shoots up. Sorry for pic size. In day to day driving you spend a lot of time at that RPM.
http://www.injen.com/galleries/produ...431_charts.jpg
Like most modifications, there is a compromise. I'm more than happy to sacrifice less than 2kw for a 400rpm piece of powerband, when the trade off is more torque thus power for the rest of the powerband in its entirety.
To answer your second question- If you understood the relationship between power and torque you'd understand my comment. Power is a derivative of torque and RPM.
Yeah I know you are an engineer - that is why you are so smart :D So am I right in saying that even a small drop in power at low RPM is going to correlate to an even bigger drop in torque at low RPM?
And the same would not necessarily hold true at high RPM?
The torque in that first Injen graph (without MR tech) is terrible. It dips below stock quite a few times in the curve - not just down low :eek: The revised Injen looks much better.
Yes you're right- As has been said many times on these forums, dynos aren't meant for pissing contests, they're a tuning tool, and they're great for measuring gains and losses from various mods, provided you try to maintain some consitancy during the testing process.
The point i was making was that, during testing, the various setups were dyno'd bonnet up and bonnet down. The results were nigh on identical, they were consistant and very repeatable.
What I was trying to express was that just because a dyno shows a repeated improvement, the improvement is applicable under THOSE conditions. It doesn't necessarily mean that the improvement will happen on the road where the airflow conditions are different. SRIs are the prime example: they'll show a marked improvement on a dyno where there's lots of air, but tend to suck in lots of detrimental hot air on the road.
The point I was making is that the SRI's showed a big loss on the dyno, which I'm guessing would have been amplified on the road due to heatsoak
There was no tangible gain anywhere on any of the graphs by running a SRI over a CAI on any of the cars we tested. (bolt on only)
What I was trying to get across was that in terms of output, regardless of heatsoak issues, CAI > SRI on the cars tested :)
