if you run high compression use arp studs
Do people not use studs? They are so cheap these days you'd be crazy not to.
agreed^
Go with oem head gasket and you dont need the AEM fuel rail. Since its a street car you dont need sleeves, stock sleeves can handle about 300kw. If you're after more power for the strip then just use good fuel.
Not investing in a even length manifold?
Welz i already bought AEM fuel rail anyways to make the engine bay look nice lolz. How much is OEM headgasket for trade price anyways SLOWEGG? i dont think i will be making any were close to 300kw? yerh i just use BP ultimate most of the time anyways wont be going to the strip that much once i break in the engine i go down the strip see how it goes then after that for my enjoyment anyways.
even length manifold? is that custom made ones eg. ram horn style ect?
Yeh like ramhorn style.. 300kw with your setup? get a nice turbo and manifold easy.
You know you dont even need to headwork, a stock head will make plenty of power. You should just worry about building a strong end build and turbo kit you can leave your head stock.
