Bonnet is spaced for the H22a Turbo Vtec in there :p
(first pic is bolted on the latches and touches the engine therefore lifting the front corner. Second one is with the back spaced so bonnet doesn't touch the engine)
If you do the swap you are also going to need the bracket on the right of this picture that the gaurd bolts up to and the bumper mounts upto.
http://i39.photobucket.com/albums/e1...6/_DSC1492.jpg
No, because the the length is different between Ek and EG, a custom bracket will be needed.
thebob, where u get ur CTR door trims?
if i change the dash, will stock door trims fit?
If i change to CTR door trims.. does the stock switch and handle fit? or i need to get all this at the same time?
Thats weird. In your previous post you say the radiator support will fit so why not just mount the bracket (welded or bolted) on the sides reletive to the radiator support so it the bumper etc would bolt up to all the "factory" points like it would on an EG.
Not having done it myself I am not talking from experience but rather seems to make sense to me that if you use the radiator support you should be able to use those brackets
Because the length of the panel from the tyre forward to the back of the light is different between the models. I know from what im doing that the JDM ITR is about 15cm longer in the front then the EK.
CTR door trims are the same man, they are just red arm rest and black vinal. THERE IS NO DIFFERENCE OTHER THEN THE COLOUR CODING. What do you mean change the dash? Then ENTIER CTR interior is the same as your normal EK hatch, just different colour coding. There is exceptions to what i just said but nothing major. EG the Climate control on the CTR 96 98 doesnt have a clock where as the AUDM civic does thus meaning you dont need to plug in the clock wire.
ah sweet thanks for clearing that up...
looking to get the 99 EK9 Dash with climate control and the double din thing coz it looks alot better than what we have here.. clock wont matter if u got an aftermarket head unit i guess
why do u say that? u saying im not capable?
its just remove the dash, change the blow heat and air con over, change some small things ova from the dash, and ur done, just time consuming thats all
