yo yo john.. reckon u can sorce me somehting. so i can make my car tunable??
P30 u think?? hook a brother up..
when i get something new.. i send down the spoon chip..
:D
:D
does this mean that the exhaust o2sensor has to be replaced?
Ain't P30 used for b16a ?Quote:
Originally Posted by Spoon-Accord
That's what my ECU is I think...
yeh.. i can't make the P13 tunable..
so they used a P30 from ur car or engine..
and make it tunable! :P
Kenny
I did this paperclip trick, and I got no flashes, which I figured was a good thing. I then unplugged my O2 sensor to make sure I was doing it right.
With the O2 sensor unpluggedm I still didn't get it to throw any error codes??? Shouldn't it throw an error code?
depends, if your got a one wire O2 sensor you will need to drive your car for a while for it to come on, if you have a 4 wire o2 sensor you should get a code straight away, code 41, o2 heater.
if you had no codes, its alll good, as long as the light stayed on.
Its a single wire O2 sensor. Nah the light didn't even come on. It comes on when I start the car, but that's it! Hmmmmm, is my car working as it should be.Quote:
Originally Posted by ECU-MAN
Quote:
Originally Posted by tegboy
Did the test this morning. Got warning code 15 - "Ignition output signal".
Not sure what this means and whether or not it's something I should be worried about.
I've found the troubleshooting procedure in the workshop manual, but it doesn't really explain what the error reported means.
EDIT: Well, I reset the ECU and it seems to have disappeared. So that's good.... I think. :p
Out of sight out of mind, eh? ;)
where did u get the ecu codes from?? what would the codes be for a jazz?
is this true?.. my engine light has been coming on at random timesQuote:
Originally Posted by bigteethygrin
when i turn car off the light just goes away
do i need to wait for the light to come on? or turn the car off and test the paper clip?
