^^^nah it's coz i touch myself at night :p
gotta touch it.. i'm cut that youtube shows vtec del sols doing 15.1 bog stock :(
but how can i put an airbox around the plazmaman/injen? the eg airbox still has that inlet shape issue as can be seen from the first pic i posted above... even if i cut that enough to hide a pipe into there and into fender.. i have the problem of having to get a smaller primary pipe that actually goes inside the inlet at the top of the box...
sigh... back to some innovating in the corner of my room
all it takes is a steady hand , a scalpel , a small hand saw and maybe a file. You can make it fit snug if you take the time.
A typical injen or plasma etc intake is 3 inches i believe - Im sure you could even cut the outlet of the airbox off and run the pipe direct ....
